m casey stock
- Apr 29, 2012
- 514
Hey Guys,
I've got steam coming from my water pump tale tale stream hole. I start the motor and at idle I get a nice stream of water and everything looks good. We can go out and run the motor at a moderate speed (mid twenties) and never get any warning lights or buzzer, I can trim the motor to where there is hardly no rooster tail around the motor sides (not from the prop, I know not to run it that way
) and see a nice strong stream from the tale tale as well. The problem comes when we slow to a medium speed around 12mph or so, in no time at all we loose the stream and start getting steam, lots of it, but still no warning light or buzzer (these two indicators were just checked for proper operation and appeared normal and okay). I was not expecting trouble, so I did not have my laser temp gun with me and have no idea just how hot it was running. We can take it out of gear and bring the rpms up to about 2K and the stream will pick back up and again everything looks normal. At this point we can troll around at about 5 or 6 mph and never show any signs of heat, just a good strong steady stream of water from the tale tale. This is not a new set up for this boat, so I wouldn't think it would have to do with height of motor on the transom and nothing has been changed or modified from the way we ran it last year. Could this just be a sign of a failing water pump impeller? It's a 2001 Merc 150 carberator (salt water addition, if that makes a difference)
Here is a picture of how it is mounted just in case.
