OMC Cobra 3.0 4 cyl GM ..... did a little work on it ... change head gasket, refurbed carb using carb kit .... replaced starter ... new points and spark plugs. Engine seems to be running ok, but Im getting steam blowing out the breather with sperts of oil and every once in a while I get speratic oil pressure and get a little clicking on the valves. I checked the oil and looks clear, but I will mentioned that when I pulled the dipstick, steam came out as well. Compression on all 4 cyls seems to be between 120-130 which according to manual is ok for this engine. Looking for ideas on how to proceed .... Im assuming water is getting into oil somehow especially if steam is coming from dipstick .... but not sure why oil is not milky.
Any help would be much appreciated ...
Glenn
Glenn
