Baylinerchuck
- Jul 29, 2016
- 2,740
Anyone have a "magic" bolt freeing juice they use to help free up seized bolts in aluminum. A couple of examples are the stainless hydraulic compression fittings in an aluminum manifold. Also the steel nyloc nut on the aluminum anode bolts that go through the mercruiser gimbal housing. This question is not specific necessarily to what I'm working on. Is there a product out the that helps to loosen steel bolts in aluminum. I have tried WD40 and PB Blaster. Also a little heat in some areas may not be an option.
Thanks
Chuck.
Thanks
Chuck.
