Steering appears to be hard
vampirefish
My engine's (1966 Merc 950 O/B, 95hp, Inline 6) steering appears to be somewhat hard (not sure what else to call it). It's not power steering so maybe I'm just being paranoid...but wanted to ask before the cable broke or something !<br /><br />I lubed 2 points (that I could find) on the steering rod (i guess you call it). Any other places I could be missing? Any other maintenance to try?<br /><br />thanks in advance!
mums360
Re: Steering appears to be hard
Hey my friend... at idle or low speeds an outboard that big will be hard to steer (your muscles will build up!). Once you get that bad boy moving along the steering will become easier (the faster you go, the easier it gets).
vampirefish
why hello! Thanks for the info..of course I haven't gotten my engine at high speeds (yet)! Read my other posts...maybe you can help me out!!! :)
mums360
I'd probably do better at helping you diagnose the charging problem.
vampirefish
Do you know if there are any other areas that I should lube for the steering?
mums360
mmmm, not sure on your deal. Did you find fittings on the 2 points you did lube?
vampirefish
yes... guess i'll wait to see how it steers once it's at WOT :D
mums360
Yeah, the prop spinning faster helps you turn the motor much eaier. You'll see. At WOT you'll think you have power assist!
vampirefish
By the way, mums360...when are you going to have some pix of your boat online? ;)
mums360
well, I'm not a web techy like you so you'll just have to come see it. what are you doing Sunday?
