64osby
- Jul 28, 2009
- 6,826
I picked up a 70 ish Larson with a 1974 135 Evinrude. Disconnected the controls today and was also looking at the steering connection. I'm moving the motor to a 1984 Hurricane sd 176.
Pic one - shows the Larson steering connection at the motor. There is a clamp/bracket which holds the sleeve or casing and allows the cable to push/pull the motor to turn. Standard newer style, I have only used the pulley/cable steering prior to this.
Pic two - shows the cable at the back of the Hurricane. There is no bracket or clamp to hold the sleeve or casing. There are no holes where a bracket would have mounted. There is a nut or collar that would screw on to _____???? The Hurricane had a Yamaha 140hp that the old owner put on his bass boat
Can anyone clue me into what I'm missing or what I need to make the Hurricane steering work on this motor. The steering cable for the Larson is about 5 feet too long for the Hurricane.
