steering cable freezing up
Re: steering cable freezing up
There's really only 1 Fix for a Worn Out Steering Cable...................<br /><br />Replace It...........<br /><br />With the pricing structure nowadays,.......<br />A Complete Helm,+ Cable is reasonably Inexpensive....................
ufm82
Master Chief Petty Officer
Bondo is right- steering cables are not worth "repairing"- replace them. When a cable breaks and the engine goes wild, you don't want to be there. Can you say U-Turn? <br /><br />You can get an entire Teleflex system for that boat for $150 or so. That's cheap insurance against a lethal failure. <br /><br />UFM82<br /><br />Spend the extra $50 and get a No Feedback system- that's the way to go.
Originally posted by UFM82:<br />When a cable breaks and the engine goes wild, you don't want to be there. Can you say U-Turn?
Ayuh,........Good Point,....... If it was only that Simple........<br /><br />The Big Problem is that it's Never just a U-turn,..........<br />The boat will constantly Circle,.........<br />After You've been Thrown Overboard,..... The boat just Keeps coming Back After You..............<br /><br />That's the 1 day in your life that you Hope it's almost Out of Gas..................... ;)
marsh deacon
Thanks for input. Replaced everything with a kit in 10 degree weather. Problem fixed.
