Steering cable help!
Al3x2015
I have a 1983 bayliner Capri with an aq125a engine and Volvo penta 270 outdrive. I need to get a new steering cable for it and I can not find one anywhere. The steering cable that is in it is a teleflex 14' sc10514 h3. I purchased a different style steering column for it though. I pirchased a steering column for the common back rack steering cable style. But I do not know what kind of cable end I need or if they even make a cable end for my application.
Yegboats
If you have power steering the kit you would need to replace your cable is teleflex ss14114 that kit comes with the sh5210p helm, sb39526p 90 degree bezel kit, and ssc13414 steering cable.
Not sure what you already purchased.
If you don't have power steering it calls for the NFB kit ss15114
Al3x2015
No Title
The kit I purchased is like the 14114 kit but it is just the steering column only without the cable but I also don't have power steering. Here is what the bottom of my origional steering column looks like As well as my original steering bar. The gear slides in the middle of the steering bar unlike the other common models where the gear is in a housing and bolts onto the bar.
Yegboats
k if you bought the sh5210p helm you need a ssc134xx cable and likely a bezel kit sb27484p
Al3x2015
Ok thankyou! I will purchase that cable and hopefully the end of the cable is the correct one for me! The kit I bought included the helm and everything so I will order the cable and will post if it fits or not.
