So my boat has been sitting about a month. I go to crank it up today and happen to notice my steering wheel is not working.
The "wheel" itself seems fine. But the motor only turns 1 direction. (turns "out")
My setup is very simple. I just want to know if this is "fix-able" or if I need a whole new cable.
Below are 2 pictures of my setup. I use a BRACKET on the transom that grips a "tube" which the cable slides in and out of. It seems like the the INSIDE of the cable has become DETACHED from the pin that connects to the motor.
Basically, when I turn the wheel so the cable goes OUT... all it really does is "push" the motor. But since its no longer attached INSIDE... it will not "pull" the motor back when you turn the wheel. I circle in RED where it seems to have become detached.
This is a small "low budget" boat... Is this fix-able? If not, does anyone have a PN for a cable?
Thanks,
Thanks,
