steering cable
palace
Does the steering cable need to be supported like remote control cables? What is the best way to support the cable?
Re: steering cable
Ayuh,.... Only by it's connections to the helm, 'n tiller...
southkogs
Re: steering cable
Bondo's gotcha' on the important part -
FWIW - My gunwale has a channel built in to run the control and steering cables through. My old boat had these "J-hook"-ish things running down the hull side. I've seen some run down a small shelf just over the floor/sole of the boat. Make sure you look for things up in the sides that may already be there.
