Re: steering cables
Mumblerone is right, hopefully you wont have to pull the engine to get it off, but usually that is the case. is the rod bent on the other side of the engine? (like its been stepped on?) If not try this, unhook the link arm from the steering cable. have someone pull hard left on the steering wheel (not too hard, some fiberglass consoles cant take too much) put a 2x4 on the end of the steering cable (left side of engine)and smack it with a sledge hammer (a straight shot or youll bend it, you dont wanna bend it) several times, if it dont budge, its shot, must be replaced.<br />rack and pinion has a long bar under the dash hooked to the steering cable, rotary usually has a round housing
