Augoose
- Mar 21, 2010
- 1,223
All,
while out on the water last week, I determined that my 1999 VP 5.0 GL with SX-M developed a power steering fluid leak. The leak is originating from the bottom of the steering cylinder, I suspect due to a faulty rod seal. With the engine running, the leak is large enough where it has a pretty good stream or trickle to it - not just a drip.
Attached are photos of where the leak is coming from. Best I can tell, its coming directly from below the split pin beneath the bolt (see photo).
Can anyone confirm the following for me?
1) Considering that it is a trickle/stream vs a slow drip, am I correct in assuming the rod seal has failed?
2) I'm considering purchasing a power steering actuator repair kit (3812269 3860883 3862210 386251). Anyone have experience with this kit?
Thanks!
Thanks!
