steering hard to turn !!!
sebasendallas
Hi first sorry about my English!! I have a 2001 vip with a 4.3 i/o mercruiser and since I have it , the steering was little hard but become harder , yesterday I replaced the power steering pomp and put the oil on it, but nothing change !! Please help!!!! Thanks
180shabah
Re: steering hard to turn !!!
steering cable possibly,
Is it equally hard to turn in both directions, or is one harder than the other?
sebasendallas
yes, it is equally hard to turn in both directions !!
Bt Doctur
most likely corrosion where the cable passes thru the tube at the transom end
sebasendallas
and what i need to do , replace the cable ? or i just can disconect and clean it
Bt Doctur
1st, go to the adults only section and download the correct manual
You will need to loosen this nut some tap it with a hammer to dislodge the bracket
remove the pin at the end of the cable and remove the cable with the tube .
find a safe area to add heat and penetrating oil to work the cable from the tube.
Once dree clean the tube ,reinstall cable using plenty of grease.
sebasendallas
thanks man ill do it tonight , but what is the adults only section ?
QC
Just a lot of good information. Item #9 is a link to Service Manuals. Nobody paid much attention until the title was changed to Adults Only. Magically there was increased activity there immediately after the change . . . ;)
sebasendallas
I took the cable out thats was the problem, but im looking to buy a new one and I see its cheaper without the pinion ( just the cable ) but I want to know if its possible separate the cable to the pinion ( the square part its go under the steering wheel) thanks agein !!!!
