I have a 1979 Century with a 228 Mercruiser transom setup. My boat always has turned left a lot sharper than right. In fact, the engine used to stall a lot while docking if you turned the steering wheel too far to turn right. I actually posted about this a year ago. Well with the engine out, transom plate etc. removed, I tried to turn the gimbal ring back and forth. There is really no excessive play, but even with the gimbal housing on the bench, it turns one way about an inch more one way than the other. The steering lever hits the gimbal housing cut out on one side and actually you can see a spot where the lever has worn the gimbal housing frame a small amount from hitting it.
Can I do something to center the steering lever?
thanks
thanks
