steering modification
Duckhunter08
hey guys, I have a 1965 evinrude super sea horse. Cover says 40 hp but engine says 33hp. Not sure what it really is. I was told that around that time the 33-40 was the same except for the carb jets. I am trying to install a steering system that i got with the motor. it is a single cable system with a steel rod at the end with internal rod that moves in and out when the wheel is turned. I am trying to install this in a way where i can tilt the motor up and lock it there without binding up anything with the steering. my boat is a 16 foot polarcraft dakota. I could have got a tiller handle but thought the steering and remote throttle system sounded more convenient but i am have major difficulties. Im a college student and money is tight so the cheapest solution will be the best, otherwise ill just try and find a tiller handle. if any pictures are available of such a setup please include. thanks, Jerry
ezeke
Re: steering modification
See if the setup in the thumbnail could work for you.
Duckhunter08
very helpful. where do you get the supplies and how does it function as far as swiveling?
