steering nowhere!!
i have a thundercraft boat with rack n pinion steering that is almost unbearable to try and steer!!i tried freeing it up but it still is incredible stiff! my boat is 4.45meters long does anyone know if i could just replace the cable or should i just replace the whole thing and if so with what?
5150abf
Re: steering nowhere!!
It would be just as easy to change the whole thing, and I would use a Teleflex no feed back system.
You will be very pleased with the results
tashasdaddy
the teleflex rotary system, is much more owner friendly, should fit same cut out.
thanks very much for the help!how does one measure for a new teleflex system do i just measure the old one and also do i remove the entire box under the dash or just take the cable out of it?
thanks very much for the help would you happen to know how to measure for a new one and do i need to take the box behind the dash(attached to the steering wheel)off aswell or just the cable.
krakatoa
My friend, take a look to this post, it could help you, there is some videos and pics. I already change my Rack and Pinion system to nfb rotary and I can tell you its GRRREAT!
