jjmesa2000
- Mar 22, 2006
- 13
I recently replace the tilt and trim bracket with one from a 1990 model. I put everything together and mounted the motor. I lubed the steering assembly and tried to work the grease. The motor would turn all the way to one side (left if your facing the motor from the front), but the farthest it would go in the opposite direction is right when the motor is straight. I'm not sure if i'm supposed to twist it a little. I know that I did not kinked the line because that was my main concern. Do I need to adjust anything before jumping conclusions.
