Re: Steering problem on my Bayliner
Well, the tach hits the read zone at 4000 RPM - 20 + knots (not 100% full throttle). I don't want to push it much harder, being that the boat is 22 years old and I need it to last. It does run really smooth overall.
You probably need to have a look at your OMC Owners Manual. It should indicate what the acceptable WOT throttle range is.....usually 4400-4800, 4200-4800 etc....AND ALL engine manufacturers recommend a prop selection that produces an RPM at the "TOP" of the range for a lightly loaded boat running at the altitude you'll run at most.......
If it will not turn in the recommended range at WOT, I.E it's LOW, you could cause engine damage even running it at lower engine speeds because the engine is "lugging".
Many "things" will result in a boat not running up at the correct speed...... aside from a worn out or mal-tuned engine:
Marine growth on the bottom of the hull, excessive weight (water-logged), boat over loaded, wrong drive ratio, wrong prop pitch, drive "trim" not at the right angle etc.....
You'll have to determine what (if anything) is wrong with your engine/drive.
Regards,
Rick
