steering question?
betayv
just replace steering cable on my sea ray 1987, 5.7 engine, I put the same kind was on the boat before the rack by Teleflex, and my question is when I turn the wheel to the left wich way the outdrive should turn?.
alldodge
It should move to the port side (left). Pushes your stern to the right causing a left turn
betayv
oh oh is going the other way, when I turn the wheel left the outdrive move right.:grumpy::grumpy:
James salter
Hi
Replacing the cable on by sea ray could you please tell me were you brought yours from
Many thanks
alldodge
Direction is seen from out side the boat, not inside. Pull the cable out of the helm and feed it in the other direction. If cable is coming out the top have it come out the bottom
betayv
james I bought my cable kit from a local wholesale supplier in fort Lauderdale, iboats have them the brand is Teleflex you need to ensure you measure your cable before ordered, all dodge your right I have to change it thanks for your help
thumpar
The drive should go to the same side you turn it to. If you look at the back of the boat from outside the drive should go left when you turn the wheel left.
