Steering repair
BlairWhitney
Hello all,
Summers here and time to try and get the boat around. Steering was a little stiff last year, tried greasing it up this year but no real luck. The boat is a Mark Twain from the late sixty's i think. Looks like it is an old rack and pinion system. Was thinking of replacing it with a rotary system.Rotech Rotary Steering System Package, 11' - Uflex to be precise. Any ideas or comments would be great.
Blair
Re: Steering repair
Ayuh,.... Welcome Aboard,.. Make sure you have the Space for the rotary,...
Rack, 'n pinions were used in alota limited space applications...
BlairWhitney
Re: Steering repair
good point bond, i think i need to do some looking around on the system i am thinking of buying. see if i can find any measurements on it.
cr2k
Re: Steering repair
Steering cables (no marine cables for that matter) are not meant to be greased. If it is the cable that is stiff it is because it is damaged on the inside.
