Steering Wheel Help
How do I re-attach the center hub to my steering wheel?
I have attached pictures of the center piece as well as the wheel. Is there some type of spring that needs to be inbetween there? It looks like the center piece has three nipples on it and it should twist into place, but it just spins and doesn't catch. Any help would be appreciated. The boat is a 60's Glasspar. (still not sure what model!)
This is the wheel with the center piece in position but no secure
Chris1956
Re: Steering Wheel Help
Put a bit of silicone caulk on it and put it in place. it will stick quite well, but will remove if you want to.
WAVENBYE2
Drill holes in it and beat it with a hammer and if that doesn't work I hear that you can silicone caulk it and remove it too if you want too!!:D LOL Just kidding I am in a good mood!
