Steering wheel is not straight
Jersey Guy
When my drive is straight my steering wheel is off about 20 degrees.
Is this a steering wheel adjustment or an outdrive adjustment?
2000 Crownline 266br
7.4 MPI L29
Bravo 3 OD
rack or rotary cable?
easy adjustment at the helm
stick your head under your helm and look
if its a rack, you unbolt the rack, index the wheel and bolt it back on
if its rotary, you pull the cable, index the wheel and re-insert the cable
roscoe
What makes you think it should be straight?
Even in a car, they never used to be straight, until they started putting radio and cruise control buttons on them.
You could install a solid steering wheel with a suicide knob. Then it would always be straight.
