Steering Wheel Locked Up
Tinjum
Bought an 1987 Alumacraft Phantom v170 and the steering wheel is locked up, am able to move the steering cable in and out of the tilt tube but still locked up, think might be a bad gear box? bad cable? Would like some thoughts on it and if anyone can help.
redneck joe
Not sure about tilt on a boat, not that rich but if you can remove the cable from the back of the wheel, inside the helm, and the wheel Don turn that tells you the cable is good.
Tinjum
Haven’t removed it from the helm/back of wheel yet, doesn’t budge in there so gotta take it all apart.
redneck joe
OK, and I'm NOT the expert but it is mechanical so I default to taking things apart. I'd start at the engine and work back. Others will want to know what kind so a pic from under the helm will help. Also, how long has it sat not being used.
