redstrat
- Dec 29, 2011
- 202
I decided to try to wrap my steering wheel to match my interior... easier said than done. Looked at some videos; 8 try later I have something I'm pleased with. Here is what I learned. 1. Make your cover to the inside diameter of the wheel. 2. Cut the vinyl across the roll so that the fabric will stretch. 3. Make the cover 1" wider than the wrapped diameter. 4. Mark the fabric on the back side 1/2" from the edge. 5. Carefully iron the edge to the 1/2" line (I put construction paper over the vinyl to protect it from melting), this can take a bit of practice. 6. Mark both folded edges at 1/2" increments. 7. Punch through the marks with an awl. (I use a closed cell foam pad under the fabric). 8. Stretch your cover over the wheel centering it where you want it. 9. Stitch it up. There are many different stitches you can use. I used a cross stitch with curved needles. I can't tell you how many hour this took me, but the next one will get done in about 6 to 8 hours start to finish.
