Steps on Removing my Lower Unit
ewalden444
Hello All,
Can someone tell me how to remove my lower unit. It's a 1998 Evinrude 35hp.
Thanks
Ed
Cofe
Re: Steps on Removing my Lower Unit
Welcome to iboats
There should be 4 bolts, and 1 nut/washer holding on the lower unit. Remove the nut/washer first, unscrew the remaining 4 bolts equally, but leave them hanging in the threads a little bit.
Then remove the water intake screens, and unscrew the two brass fittings on the shift rod, turning only the upper one because if the lower half is turned the shift linkage length could be changed.
Then use a pair of needle nose pliers and slide the upper brass fitting up the shift rod. Next carefully remove the plastic ferule that was underneath the brass fitting. The ferule has a vertical slit, use a finger nail or small screwdriver to open the slit, and remove. Shift the gearshift in forward position. The upper brass nut should be then removable. Lower the lower unit slowly. The drive shaft slides out on its splines. Good Luck
