Steps to remove tilt and trim
Span 24
I want to remove the tilt/trim motor/pump unit from my 03 Starcraft/Volvo-Penta SX-M Outdrive and would like some advice on removing and replacing it with a new unit. I have attached a picture of the current unit but believe that it is not the original.
I have the electrics disconnected as well as the mounting screws. I only have to disconnect the hydraulic lines and remove the unit.
Do I need to take any special precautions when disconnecting the hydraulics?
Is a bleed required after the new unit is installed?
Any help is appreciated!
Michael
Re: Steps to remove tilt and trim
Ayuh,... Put the drive Down 1st,... Then it's No problems,+ No bleeding...
Span 24
Got it off without a hitch!! THANX!!
Michael
