PITBoat
- Jul 26, 2018
- 286
I'm draining mine this evening, after checking it the other day and finding it pretty dirty. There wasn't any water in it, and I was pleased to find hardly any metallic material on the tip of the drain plug, so I'm hopeful that the condition of my drive is good. PO had no records and I don't remember when/if he mentioned the last change date.
Going to try to lube the "steering ram" and "actuator valve fitting" before hopefully taking it out tomorrow to test out my new tach.
I started to take off the fuel/water separator filter the other day, but wasn't prepared to catch the gas that appeared to be going to drain. The date on that is from 2016.
