GuinnessGuy74
- Jun 8, 2004
- 21
Yesterday, I had just changed the prop on my Alpha I Gen II. 5 mins later cruising around 3500 RPM, there was a loud bang. Engine would rev high with no movement. Though I had lost the prop but it was still there. No forward...no reverse. I know the drive is shifting by spinning the prop by hand. It is not the engine coupler since I can see the shaft spinning. When engaged in forward or reverse, nothing happens. Exactly as if I was in neutral. No noises either (metal scraping, gears grinding). Any thoughts as to what happened? Thanks for the info........<br /><br />Jim
