Stern Drive Raises Up in Reverse
kwoolard
When I shift into reverse and rev it a little, as when I am docking my stern drive raises up on its own. What would cause this to happen"? Is there a check valve somewhere that is failing?
Haut Medoc
Re: Stern Drive Raises Up in Reverse
Reverse lock valve.....
Located on the shift plate.....
The one with the microswitch & hoses...
Merc. Manual #2 pages 7 A-9 -7A-11, descibes how to test it...........JK
kwoolard
Isn't that just a switch to kill the power going to the pump? It doesn't close a valve right, just the power to the trim pump?
Bt Doctur
kwool, part is the reverse lockout valving and the other is the shift interlock switch.
Could be low on oil or has a lot of air in the system.
Alumarine
On my boat the shift interrupt switch is screwed onto the reverse lock out valve (the thing with the hydraulic lines going to it) if that helps.
