stern drive repair. help i'm a noob
asthesun
i bought an 88 four winns 16' boat with a 3.0 and a R - MR - Alpha One stern drive. first day out i hit a rock and the bearing in the top portion of this unit was destroyed, the bearing that sits in the cap. part number 94998A4, which is the bearing and the cap, since the cap was damaged too. the bearing parts tried to get caught between the two gears that are under that cap and i need to clean out the area before i put the new bearing and cap in. i need to either free-rotate the whole mess so i can get the metal shards between the gears or if that isnt possible, i need to take the whole thing apart i guess. anything i should know? i really just want to free rotate it and blow it out with a compressor. dont really want to take it apart... help! also, idk how to do any of this since im a noob
Brewman61
Ensign
Re: stern drive repair. help i'm a noob
You also posted this to another forum which is where I replied.
achris
More fish than mountain goat
How did hitting a rock destroy the upper gearcase? Most likely cause of top bearing failure is lack of oil....
The whole unit will need to be stripped and cleaned out. Then once ALL the new parts are available, you will need to set up the backlashs and preloads with the correct shimming tools. Not a job for a beginner...
Best and cheapest option would be a new SEI drive, complete.... The ratio you need is 1.98:1....
asthesun
arrr and it was suggested i move it here
asthesun
yeah, i thought it was odd there wasnt much oil. is it supposed to be slap full or just with a bit? either way i know there wasnt enough
asthesun
know a good place to get a new unit?
ziggy
there ya go. available right here on boats i believe.
that's what i think i'd be doing too. looking for a whole drive. metal fragments of the destroyed brg. would be the enemy in all parts of the existing drive. oem tool cost would be the obstical for repair of what ya got.
sei=sterndrive engineering drives. they are after market drives. copys of mercruiser stern drives. http://www.sterndrive.cc/
asthesun
cool. i surely didnt know what SEI was. he sais i nees 1.98:1 but i dont see it here http://www.sterndrive.cc/mm5/merchant.mvc?Screen=CTGY&Category_Code=MercruiserAlphaUpperSterndrive
where can i fond for sure the one i need?
ziggy
whats the difference between the 1:94 and the 1:94 old unit?
? gear ratio is gear ratio. they're the same.
the gear ratio change occurs in the upper. lowers are all the same best i understand...
achris
A few years back the ratios available from Merc were...
1.50:1
1.65:1
1.84:1
1.98:1
The tooth count in the upper gearcase is the main determining factor in the overall ratio.
About 1996 Merc changed the tooth count in the lower gearcase to 'reduce gear noise', and the new ratios are as follows...
1.47:1 (replaces 1.50:1)
1.62:1 (replaces 1.65:1)
1.81:1 (replaces 1.84:1)
1.94:1 (replaces 1.98:1).
The change in overall ratio is not significant enough to need a prop change, so order either a 1.98 or 1.94... As far as that engine is concerned, they are the same.....
asthesun
1.50:1
1.65:1
1.84:1
1.98:1
thx ur awesome. just wondering, anything i should replace by default when doing this swap? i see when im viewing this unit that it recommends a seal kit.
achris
Depending on the age and condition I would also be looking at the bellows (all 3) the gimbal bearing, and the shift cable. If the upper shift shaft bushing is the old style, then change that too.... Usually the transom seal doesn't need replacing. (b1tch of a job if it does). One common problem on those units is the steering arm gets worn and you end up with a stack of slop. If that's the case you may need a gimbal ring kit ($$$)....
asthesun
guy i bought it from said the gimbal bearing and bellows was new. he explained it has the modern version of the bellows (which doesn't look like a bellows)
achris
He may be referring to the exhaust 'bellows'. If it's just a tube, then it's the old V8 style and should NOT be used on that engine....
rickryder
Can you elaborate on this sloppiness.... where will the wear be seen? side to side swing of the unit?
I can grab my unit (lets keep it clean guys :) ) and swing it left to right about 2-3" is that normal?
achris
That's exactly the slop I'm referring to. It indicates a worn steering lever. The only way to visually inspect it is to remove the drive, engine and transom plates. What you need to do is have a friend move the drive side to side while you are on the inside of the boat watching the steering lever... The 'normal' movement (on a unit with no wear in the steering lever) is about 1/2" before the steering arm starts to move the steering cable... If you have significantly more, then it may be time for a gimbal ring kit... That has a new gimbal ring, steering arm and what's called a 'square/square' upper swivel shaft....
