1994almeida
- Mar 29, 2006
- 140
Hi
I plan to remove the stern drive unit SX-M, from year 1999, in order to lubricate the U-joint and inspection of the Bellows. Is my first removal, by myself, so I have some doubts.
1. To remove the stern drive SX-M the unit should be in Forward or Neutral Gear?
2. In order to remove the Shift Cable is necessary to remove the pivot cube and nut (inside de drive) and also the shift cable anchor clamp screw (on the outside starboard of the drive) ?
3. And after, how is the shift cable disengaging ? Puling, unscrew ?
4. To install all, is in the reverse order?
Thanks Almeida
Thanks Almeida
