stern light not working
qt73937
My bow light works but not my stern white light. I think it is the light base because I've confirmed the white light does work. Is there something I can use to push/pull the pins inside the base out so I can maybe clean them....or do I just need to buy a new one and rewire? I've changed out the switch and circuit breaker so they are new.
Fireman431
Re: stern light not working
First use a test light or multimeter to make sure you have a ground and 12v+ going to the light socket.
If you do, a little emory cloth or sandpaper to scuff them up. Then a light coat of grease or other protectant.
If you decide to replace it, look into LED's. Minimal power draw and 10,000 hour bulbs if you get a quality lamp.
D
DJ
Guest
They are a contant souurce of issues. The pins never seem to hold their tension.
I just hollow out the base and extend the wires to a two prong plug below the pole and base.
qt73937
Thanks for the reply. I checked with a test light with the switch and power turned on. I do not have a ground and 12v+ going to the light socket. Like I said I just changed out the switch and the circuit breaker below the switch and testing them with a test light do show that I have power. Is there something else in between the switch and socket that I'm not considering?
Fireman431
More than likely you lost a ground OR the 12v+. Rarely would you lose both.
qt73937
Fireman, you are right. I checked again and I only have 11.7-11.9v going to the socket. What's my problem? Thanks in advance and sorry for my lack of knowledge on this topic.
Fireman431
11.9 is pretty close to 12 volts, especially if you're doing this on an older battery, if the boat hasn't been run for a while to charge the battery, or if you've been messing with the lights for a while. Aside from that, there is going to be a slight voltage drop from the battery, thru the battery switch, thru the bus bars/fuse block, thru the dash switches, then out to the lamp itself. Additional drop if theres corrosion involved in the circuit.
Concentrate on getting a ground to the lamp socket and your light will work.
qt73937
I followed the wires to a main connection point with a 9 pin connector. When I pulled the connector apart, I found that the pins both male and female parts were badly corroded. I'm sure this is the reason for my drop in volts, will repin and replace connector. thanks.
