Sterndrive Model?
Jamepc
What model sterndrive am I most likly to have coupled to my '85 Mercruiser 120? R, MR, Alpha, Alpha Gen II....? I have the lower unit listed on Ebay and want to put the correct model number in the description.<br />Thank you.
achris
More fish than mountain goat
Re: Sterndrive Model?
1983 is the 'R'. You should also list the ratio, which for the 120 is 1.98:1<br /><br />It will fit on any V8 engine up to 1990, or in-line from 1983 to 1990.<br /><br />Chris......<br /><br />Before the 'editors' jump all over me, yes I know that the V8 chevs use 1.5:1 ratios. You can still use the 1.98:1 if you change the prop.
And I Thought the 83/93 was the MR/Alpha 1........<br /><br />1985 I Know is an Alpha 1.......<br /><br />And,.... The Alpha 1s,+ the Pre-Alpha R drives,.. All have a 1.65/1 ratio in the Lowerunit....<br />Final Drive Ratio is determined by the Upperunit Ratio.........<br /><br />Chris,..... You otta Go Fishing...... Or to Kamchatka......... ;)
achris
Originally posted by Bondo:<br /> <br />Chris,..... You otta Go Fishing...... Or to Kamchatka......... ;)
I know, I know!!! <br /><br />Talked to the boss yesterday and he's got me on a job in the Phillipines, starting in about a week. That should keep me off the streets :D <br /><br />In the meantime, have a look at this chart, taken from the Mercruiser Service Training notebook. It lists the years and models of engine and drive units.<br /><br />Interesting that the MR was only used for one year, 1985. There's another page (not scanned) that shows the Gen II first started in 1992.<br /><br />Chris..........<br /><br />
OK,......<br />So,... The Lower unit in Question is an "MR",......<br /><br />Which is the Transistion unit from the "1-R" to the Alpha......<br />I Believe the "MR" is More of an Alpha,.. Than it is an "R"....I know the "MR" Looks like an Alpha.....<br />Atleast as far as Interchangeability.......<br /><br />I guess that My timeline would be More accurate if I said the "R"s were used To 84,+ the Alphas were used up To 93,+ the "GenIIs" there after.......
achris
Originally posted by Bondo:<br /> OK,......<br />So,... The Lower unit in Question is an "MR",......<br />
Yeah, howd I miss that? Sorry James. Original post said '85 and I go giving the data for '83. Time for a holiday! <br /><br />If you need me, I'll be packing my bags (for Petropavlovsk :D )<br /><br />Chris.........
Jamepc
So would the '85 be a Pre Alpha or Alpha Gen I or more of a mixed breed unit?<br />Thanks for the replies!<br />James
achris
James,<br /><br />Look at the chart. 1985 is MR, that's before the Alpha.<br /><br />"Pre-Alpha" covers everything before 1986; MR, R and MC-1. <br /><br />Chris.........
Jamepc
Chris,<br />I did look at the chart, thanks it was very helpful. But like Bondo stated, it's more like an Alpha unit then a pre Alpha. How about the lower unit itself. Is that pre Alpha or Alpha (not in name but characteristics). Should it work with all Alpha Gen I upper units?<br />Thanks again for the clarification.<br />James
For Lower Unit Interchangeability,........<br /><br />Look for the "Pre-Load Pin" in the Input Shaft........<br /><br />Those With the pin are for Pre-Alpha, Rs, Mod.1s, etc......<br /><br />Those WithOut the pin are a Swap for the Alpha 1s,.... Up To(but Not including) the GenII in 93........<br />
Ayuh,........... So long as there's NO "Pre-load Pin".................
achris
Personally I don't like the term "Pre-Alpha", that covers too many units. I prefer to call an R unit an R. No confusion then. <br /><br />Many of the parts in the MC-1, R, MR and Alpha Ones are the same, or the earlier ones supercede t the later ones. Most of the parts in the upper unit are the same. The lower unit is a bit different because they changed the direction of load on the drive shaft bearing. The earlier ones had a pre-load pin in the top of the shaft, thus the bearing (under the water pump) was installed to take the load in that direction. The later ones (MR and Alphas I think) have no pin and only when there is load on the shaft does it rise up and the bearing takes the load.<br /><br />As for your unit, the top and bottom housings are completely interchangable with the other various units. You can use an MC-1 top with an A1 lower, or an A1 upper with an MR lower, whatever you like.<br /><br />
Short answer? Yes.<br /><br />Sorry about the confusion.<br /><br />Chris.
Agreed,........... But,...<br /><br />It Still gets Extremely Confusing.......<br /><br />'Cause,.. Is that R-drive a 888,.. or a 898,..... or a 470,..... or a ???????????????????<br /><br />Mercruiser Likes to give Hundreds of Names to essentually the Same Drives........
Jamepc
I guess a pre load pin would be obvious, right? All I see at the top of the shaft is an o-ring.
Jamepc
Bondo / achris,<br />Thanks for the replies and links. You helped me answer many questions I received from people inquiring about my Ebay lower unit.<br />Regards,<br />James
Jamepc
Bondo,<br />Let me get a clarification here. The mercstuff.com site says the CASE is interchangeable. Does that mean a loaded (gears and all) Alpha lower will or will not fit a pre-Alpha? Or just the case fits?<br />Thanks again!<br />James
I Haven't Tried it,.......<br />But,..<br />I Understand that the Alpha Lowerunit Can be run on the Pre-Alpha Upperunit,........<br />But,.. Not the Other Way Around, Pre-Alpha Lowerunit on an Alpha Upperunit............<br /><br />Hopefully Chris or Don or Rodbolt or Somebody will Clarify this...............
