Sterndrive stuck to pivot housing
pdowning
I've removed my sterndrive and pivot housing but I cannot get them apart. I've tried penetrating oil, hammer & chisel, hammering on the studs, no luck. Any suggestions? Would a shop have some type of puller that might work, or are they going to charge me $70 per hour to beat on it with a hammer?<br /><br />Thanks
Don S
Re: Sterndrive stuck to pivot housing
What kind of drive and pivot housing are we talking about?
pdowning
It's a 1999 volvo penta DP-S. Any advice? It's almost as if the two parts are fused together.
Don S
No special tools for that. Sounds like it's been in saltwater and has never been off.<br />It's probably going to take lots of heat and some possible drive work when done.<br />Doesn't sound like an inexpensive repair to me.
pdowning
Thanks Don, this is about the 4th time you've given me good advice. I'm taking it to the shop. My next step was going to be chaining the drive to a large tree and the pivot housing to my large truck and pulling them apart.
Don S
Holy Broken Outdrives Batman........ :eek: :eek: :eek: <br /><br />Good thing you are taking it to a pro.
rodbolt
are you sure you took all 4 bolts off? I assume your trying to seperate the upper gearbox from the intermediate housing. if the corrosion has locked the two studs its a bit fun. I use heat and use the studs as jacking screws. in the salt pond if it does not come apart every other year or so for maint it may not come apart when it needs to.
olbuddyjack
You been talk'n to Bondo? :D
Don S
From the above statement, I assumed he meant he was trying to seperate it at the red line in the picture below.<br /><br />
pdowning
That is exactly where I'm trying to seperate it. I've talked to two shops. One said he can get it done next week, the other said he would try, but can't guarantee he won't break it. I'm not taking it to him. Should I be worried about someone breaking my expensive drive?
Don S
I would have made the same statement, regarding breakage.<br />Like I said right to start with it's going to take a lot of heat and some possible drive work.<br />The drive needs to be heated so the studs attached to the pivot housing pull out of the drive. And that may damage some seals, but breakage would probably be the pivot housing itself, not the drive.<br />The way it got that way to begin with was lack of maintenance. No way would a drive hang up like that without years of corrosion.......Well, unless someone put Never Sieze on the studs. That would sure lock them up tight in a short time.
pdowning
Makes sense. The guy I got it from had it in the water behind his house in Fort Lauderdale for 3-4 yrs. Never used it, never took it out of the water
rodbolt
I am with dons on the breakage. but usually with enough oxy/acetylene I can get the loose. the drive shaft bearing box also gets water then corrosion around the bearing box and the pivot housing. which is why i always beat up on the maint issue. if its in any water that crabs are its salt, dont care if largemouth bass live there too. :) <br /> i have had to destroy the pivot housing with a side grinder and cut all six studs, but only once.
DHPMARINE
If you put a 2x4 between the crown of the outdrive,and the tramsom plate,or the transom,and hit the 'up' button .... what would happen ??<br /><br />2x4 break ?<br /><br />hole in transom ?<br /><br />Trim motor stall ?<br /><br />Let us know,please.<br /><br />DHP
Don S
DHP, he already has the drive and the pivot housing removed from the boat.
rodbolt
yep and its gonna be harder to wreslte that way. but not impossible.
DHPMARINE
sorry Don S,I was looking at your post above,with the red line thru it.<br />Never tried it myself,(don't know why I would) but can you pull the pivot housing and the drive at the same time ?<br /><br />DHP
pdowning
Well, they broke the housing. It was on there pretty good, so I'm not surprised. Don was right, it took a lot of heat & chiseling. Does anyone know where I can pick up a new pivot housing, preferably used?
Leave town for a week,......And I'm Already being Teased........ :rolleyes: <br /><br />BTW,........ It Does Work....... 'Course,.. It's Easier when it's Still hooked to the Boat............... ;)
