rtoomey641
- Jul 8, 2016
- 93
Please Help had overheating problem went to change seawater pump looked fine changed any way started up ran good but when temp went up it went from zero to 220 instantly took apart impeller burned no water put old impeller back in new pump housing and put lower end in tub of water spun shaft clockwise with drill no water coming out there is no blockage 5.0 mercruiser with alpha one impeller is spinning as it lines up with keyway when I check when I took lower end out the top o ring wsa not there or up in housing
