Sterndrive winterization
jimrockireland
I have a SEI106 sterndrive and a MCM228 engine. I live in New Hampshire and store my boat in my unheated garage during winter. What are the pros and cons of leaving the sterndrive mounted on the boat during winter? I usually remove the drive during winter and store it upright in my basement. If left on the boat should it be in the down position?
generally you want to pull the drive every year for the annual maintenance
however yes, store it down.
you still need to do all the winterizing maintenance
JASinIL2006
If you?re leaving the drive on the boat, you need to do winter maintenance on the drive before the weather gets cold. If you store the drive in the basement, you can do it later when it?s nasty outside. I like saving work on the drive for the winter when I?m longing for boating weather.
Wither way, winterization of the engine still has to be done before cold weather sets in.
QBhoy
Leave the drive down and fill the thin pipes off the thermostat with antifreeze until it overflows out the drive....all good.....unless you are in the green peace core 🙈
QBhoy
And make sure you either change the drive oil or check for water.
