stick steer
outlaw sx
ok im in the process of rebuilding my grumman outlaw sx I have a 115hp yamaha jet on the back. can i convert this boat to stick steering or am I barking up the wrong tree. I noticed that ezy glide sticks are only rated for 90hp max is this before or after you lose the 30% for your jet thanks:confused:
tashasdaddy
Re: stick steer
i would say after, as the 90 hp is rated at the prop, (output of the jet) 115 putting out approx 80 -85 hp, i have use the ezy glide system on several boats and 100% pleased.
outlaw sx
Re: stick steer
ok now that i can do stick steer what other things will i need i know i need the stick and cable of course throttle cable and the gate cable where do i get this stuff and how much thanks
Lion hunter
Re: stick steer
I beleive they will have everything you need right here on iboats. It will normally be on your door in 3 days.
tashasdaddy
Re: stick steer
you need the stick steer system, and the controller for your particular motor.
