Sticking Throttle
stephank
The throttle on my 1989 Maxum is sticky from forward to neutral and neutral to reverse. The following was suggested:
"Have you adjusted your throttle friction screw on the remote control? It may be too tight... "
Where is this screw and how do I adjust it?
Thanks,
Stephan
cr2k
Re: Sticking Throttle
Need more information. What brand of power package? OMC Mercruiser ???
If it is an I/O it could be your short shift cable and not your throttle at all.
A friction adjustment will be the same thru all throttle positions.
Need more info. Maxum tells us the hull builder not the engine/drive option.
stephank
Thanks for your help....It is a Mercruiser i/o....little straight 4...I believe an Alpha I out drive.
stephank
The short shift cable??? I am very mechanical as far as cars go, but I am new to boats. What does this mean, can I fix it?
Ayuh,... Go to the I/O Mercruiser forum, 'n search changing the Lower shift cable...
There's an article in the Adults Only section pinned to the top of that forum...
