Hello, I've got an 88 Marlin, 4.3 alpha 1 with a 2 barrel Mercarb..I adjusted the electric choke last year and have had no issues up until now. The last couple times out the choke will set properly when I pump the throttle. On start up it will start fine but becomes too rich quick. The butterfly plate will not rotate to a vertical position on its own. This requires me to pop the flame arrestor off and manually move the plate to the vertical position. This immediately resolves the issue.
Any thought as to why this might hang up? I plan to take a closer look in the next couple days but was looking for some likely causes from you all.
Thanks..
Thanks..
