Sticky lifter
pogi
Hello, I ran my boat on sunday and it ran fine, then today when I started it it sounded like a stuck lifter. So I pulled the valve cover and sure enough the lifter in question was sticking. Can a sticky lifter cause a bent valve? After turning the engine over without starting, the noise went away and the lifter seems to move OK, but the engine is running rough now. Can a sticky lifter cause a bent valve? 1978 Merc cruiser Chev. 305.
Black as
Re: Sticky lifter
It sure can, you need to also check the push rod as well as that also may be bent. But more likely the push rod, but check everything
cr2k
Re: Sticky lifter
Might be time to run a quart of Rislone in the engine and then change the oil after a few outings. It will help unstick anything else that may be lurking.
You didn't say but is this a ford engine?
Bt Doctur
Re: Sticky lifter
No, but a sticking valve can cause a bent pushrod.
pogi
Re: Sticky lifter
Thanks for the help, I should be able to pull the rod out and check it right?
Black as
Re: Sticky lifter
Sure can and that's a easy fix, good luck ;)
