I've bought a 1987 85 hp Force outboard from someone having idling problems when I went to see it everything seemed to be turning OK. When I put it on my transom about a month later and after cranking it for a while It has one very tight spot on the rotation that the starter barley overcomes. (just as the first piston begins to go down from TDC) it is also very tight turning by hand the piston walls are not scored and there seems to be a large pressure relese when it passes this tight point. Also under the flywheel is a stater I wondered if it might be scrubbing there making rotation hard. I've removed the spark plugs and I get the same issue. Does anyone have any insight? I mostly work on automotive engines myself so I'm new to outboards and 2 strokes in general.
