sticky zipper
torcano
The zipper on my sunbrella side curtains is hard to slide. Any suggestions for a proper lubricant. The zipper is plastic/vinyl not metal. I assume vasoline petrolium jelly can't hurt.
Thanks,
RK
ebry710
Ensign
Re: sticky zipper
Silicone lubricate (and candle wax) should work. I would not usually suggest the use of petroleum jelly on petroleum derived products. Of course I do not usually use petroleum jelly and that might make less of an expert.
aspeck
Re: sticky zipper
Either a bar of soap or a candle should help.
torcano
Re: sticky zipper
Thanks. I have still have my left over birthday candles and will be putting them to good use.
RK
bjcsc
Re: sticky zipper
I've never had any luck with wax on plastic zippers. There are products made for them that work very well.
firehog6305
Re: sticky zipper
I have been useing chapstick, and it works good too
The Old Geezer
Re: sticky zipper
Go to your grocery store and in the canning supplies pick up a package of parafin . It is used to melt on top of Jellies etc. Just rub it up and down tthe zipper and it will stay on and solve the problem . It also will not soil clothes or other items and works on all types of zippers. The Old Geezer
torcano
Re: sticky zipper
BJCSC, thanks. The Star Brite lubricant worked great and it appears to work on the snaps as well. It was more expensive than candles ($8.99 at West Marine) but appears to be made specifically for the job at hand.
RK
bjcsc
Re: sticky zipper
No troubles, I think it works great, too. It will also keep your snaps from getting crusty/green...
