Stiff pivot action on '89 50 hp Evinrude (not steering cable or transom tube)
Edthetermite
I have the engine hanging on a hoist without the transom mounting bracket. The pivot action is very stiff. Since I am just learning boat engine terminology I think it is the "swivel bracket" that is not moving as freely as it should.
What is the correct procedure for disassembly? I have an Evinrude Service manual but have yet to find info on this area. Since I have the engine off the boat to replace a defective steering cable I figured this was a good time to address the stiff pivoting problem.
Any tips certainly appreciated. Thanks.
F_R
Sorry you have to remove the powerhead and lower unit before you can take the swivel bracket apart.
Edthetermite
I dont think it has a friction screw. I thought about trying to heat up the swivel bracket and then inject new grease while still warm. Really dont want to pull powerhead and lower unit unless absolutely necessary.
