stiff throttle on Yam F115
rbc
New to me boat has a stiff throttle. Seller told me dealer said it was normal on this boat and motor. Doesn't
sound right to me. Anyway I opened up 703 remote and fooled with tension adj. and no change. Was this just a poor setup by dealer or is there another adj. somewhere?
thanks
Ray Neudecker
Re: stiff throttle on Yam F115
Good chance the bind is in the cable itself. Welcome to the world of corrosion.
rbc
Boat is a saltwater boat but is 2005 so I wouldn't suspect corroded cables already. But hey who knows. I was thinking of trying to disconnect cables at motor and making sure engine portion works ok and see if cable action feels stiff while disconnected.
rbc
Just in the off chance anybody is listening, I disconnected throttle cable from throttle adjust on motor and it still felt stiff at the 704 CB. I was just moving throttle not gears. Actually moving the throttle on the motor is pretty stiff also at least compared to carb engines.
I started to look closer at 704 cb, I had previously tried to adjust throttle cable tension with the two screws on top of CB that had locknuts. No change so I sort of assumed cable was prob. I found screw at lower front of CB that moved a little as I moved throttle. Gotcha- that screw is the cable adjust screw, not the ones with locknuts.
Throttle now moves easily, yet to try on water but right now feels much better.
