Still getting a nasty noise from one of the pushrods on my Mercruiser 165HP IL6
Skipster1
I did a non-running adjustment on all rocker arms and I still get this nasty noise ... I believe it comes from the forward-most piston.<br />This is a distinct, sharp noise... not a dull, thunking sound and it comes from the top/front of the engine (not down deep in the engine). I feel certain it is one of the two front pushrods but do not want to tighten too far????????<br />My big concern is over-tightening. If I over-tighten 1/2 a turn will that cause real damage?<br />Also, how can I determine which pushrod is noisey? It is not possible with the engine running?<br />Thanks,<br />skiph
Re: Still getting a nasty noise from one of the pushrods on my Mercruiser 165HP
I Think we've already gone thru this,<br />But,<br />Do the Running adjustment............<br /><br />IF it doesn't quiet down then,<br />You've got a Collapsed lifter..... It'll need Replacing......<br /><br />From your previous posts,<br />I don't think you're getting then Tight Enough......
Skipster1
I would do the Running adjustment but am told I need the "sequence".... which I never got???<br />Also, I cannot quite hear which pushrod is making the noise even though the sound is coming from the top.<br />I pulled the two front pushrods and they look fine.<br />Thanks,<br />Skip
djvan
Should be no sequence for a running adjustment, just loosen one until you here it "clacking" then tighten until "clacking" is gone, then turn an additional 1/2(?) turn. Can't remember how far to turn beyond "clacking" silence. Somebody else will chime in I'm sure.<br /><br />DougV>
3/4s to a Full Turn.......<br />1/4 turn, let it clear, another 1/4, Etc.....<br /><br />Just Start at the Front.......<br /><br />You Need the "Sequence", Only when doing the Static Adjustment you Just Did.........<br /><br />This is a Chevy,<br />With Hydrualic Lifters.....<br />They're Adjusted to a Range........<br />Not to a Thousandth.........<br /><br />They're, in Essence, Self-Adjusting........<br />You just have to Pre-Load them........
