markhodges78
- Aug 4, 2016
- 423
I have been fighting shifting issues with my Alpha 1 gen 2 drive with s/n 0F321918 for a few years. It started out ratcheting 1 day out of the blue In forward gear so I made an adjustment to the control cable to get off the water. Once I got home I adjusted the cables using the method on youtube posted by achris. After making the adjustments I had forward but no reverse not even a ratcheting sound just dead neutral. So I moved the slide pin on the shift cable all the way to the farthest position before I could get reverse to engage. That worked for a while but then started ratcheting again. So here is what I have done this far.
1st I replaced the shift cable and the cable end shift slide. That fixed the ratcheting problem but I still had to use the farthest position on the slot to get reverse to engage.
2nd I replaced the bushings and seals for the upper shift shaft. Still had to move the pin to farthest position on the slot
3rd I replaced the shift shaft and the upper lever assembly arm. Still had to move the pin to farthest position on the slot
4th I've just replaced the remote control went from a 3000 to a 4000 with new oem cables still I have to use the farthest position In the slot. It's working. so far so good but if anything was to stretch I'm out of adjustment and im not sure why its fighting me so much. I'm out of ideas at this point.
