still need help..rpm loss
wally jr
22' 84 bayliner aq125a... boat wont go over 3000 rpms, it's not even enough power to plane. just did a tune up. plugs,wires cap/rotor. last year i put new coil,starter. my friend just told me to put a condenser also. could a condenser create loss of power? what else could i check? or trouble shoot? temp is good and runs/revs to over 4000 in the slip.
MooseHootie
Re: still need help..rpm loss
Is it starving for fuel, mabe obstruction in fuel system ?
fish393
No mention of the carbs?Clean them well if not allready done or do it again.Rebuild fuel pump?How old/last serviced.Check fuel pressure and clean all filters. good luck
in the slip.
What's the Bottom of your boat look like ???????<br />How long has it been since it Would make WOT ??????<br />
Nope.........<br />It either Works.... Or it Don't........
wally jr
the bottom has been painted every year exept this year and it sat in the water all winter.. just had it pulled for the prop and the bottom really is not bad.. some slime, soft growth.. i understand i might lose a couple knots but rpm loss too? were talking almost 2000 rpms. tommorrow night i'll mess with the fuel system. i have no idea where to start or what to do. is there a fuel filter? i also had just under a 1/2 a tanke of gas sit over the winter (25 gal). maybe fuel quality?
fish393
If you have solex carbs I can help you.Very easy.did you use a gas stabilizer?Should have fuel filter in fuel pump.A brass colored screw take out and see if clean? post more info.Volvo overhead cam correct?
hoot
check timing and advance, volts at + side of coil, alternator charging, exhaust restrictions. my engine has a fuel filter in the carb and one at the pump.
metwrench
Like Bondo said, Condenser only prevents arcing of the points..Really plays no part in overall performance unless it allowed the points to burn and the contact set is not making good connection for coil build up time.<br /><br />I would also go toward Fuel ? what kind of Carbs ? is it Backfiring or coughing at all ?
It doesn't take very Much, to Overload the motor.......<br />Especially when you start with such an Anemic motor to begin with.......
