Re: Still Needing Help with This I/O Problem
terry<br /><br />it would have been better to add this to your first post about the oil pouring out <br /><br />every one wil be able to help you more if they no as much as possable<br /><br />
<br /> 0 0982570 0983505 SEE PRICEBOOK 1 Please Call Please Call <br />1 0982794 0984978 Use 0984978 1 $1,057.14 $951.43 <br />2 0384195 0384195 NDLE BRG,BH-1820 1 $16.99 $15.29 <br />3 0324852 0324852 RETAINING SCREW 1 $4.61 $4.15 <br />3 0307853 0307853 SEAL 10 PK 1 $0.51 $0.46 <br />4 0323466 0323466 SCREEN-WTR INTAKE 1 $4.35 $3.92 <br />5 0314728 0314728 O RING 5PK 1 $0.94 $0.85 <br />6 0982422 0982422 BRG HSG AY 1 $104.36 $93.92 <br />7 0321467 0321467 SEAL 2 $9.36 $8.42 <br />8 0301250 0301250 WASHER 4 $2.63 $2.37 <br />9 0910539 0910539 PIN 1 $21.63 $19.47 <br />10 0910311 0910311 RACK-SHIFT AY 1 $76.54 $68.89 <br />11 0306358 0306358 WASHER 1 $3.13 $2.82 <br />12 0306376 0306376 COTTER PIN 1 $0.27 $0.24 <br />13 0391365 0391365 BRG HGS,PIN&SPRING 1 $132.60 $119.34 <br />14 0382407 0382407 NEEDLE BRG 1 $15.96 $14.36 <br />15 0202136 0202136 PIN 1 $2.05 $1.85 <br />16 0322900 0334163 Use 0334163 1 $11.60 $10.44 <br />17 0324037 0324037 SHIFTER LEVER 1 $12.74 $11.47 <br />18 0322941 0322941 SHAFT-SHIFTER 1 $58.15 $52.34 <br />19 0320145 0320145 PIN 1 $3.99 $3.59 <br />20 0313446 0313446 O-RING 10 PK 1 $2.15 $1.94 <br />21 0313445 0313445 RING 2 $11.89 $10.70 <br />22 0314732 0314732 PLATE 1 $27.91 $25.12 <br />23 0302290 0302290 LOCKWASHER 5 PK 6 $0.78 $0.70 <br />24 0384523 0397087 Use 0397087 1 $225.69 $203.12 <br />25 0382407 0382407 NEEDLE BRG 1 $15.96 $14.36 <br />26 0379504 0379504 NEEDLE BRG AY 1 $12.51 $11.26 <br />27 0321463 0330137 Use 0330137 2 $7.40 $6.66 <br />28 0316563 0316563 SCREW 5PK 4 $2.53 $2.28 <br />29 0317178 0317178 SEAL 10 PK 1 $1.22 $1.10 <br />30 0314731 0314731 THRUST WASHER 1 $11.08 $9.97 <br />31 0314730 0314730 NUT PINION 1 $8.87 $7.98 <br />32 0910338 0910338 GASKET 1 $2.28 $2.05 <br />33 0387656 0387656 THRUST BRG AY 1 $27.65 $24.89 <br />34 0327656 0327656 THRUST WASHER 1 $7.64 $6.88 <br />35 0982423 0982423 DRIVESHAFT 1 $563.76 $507.38 <br />36 0393633 0985050 Use 0985050 1 Please Call Please Call <br />37 0317838 0345992 Use 0345992 1 $130.02 $117.02 <br />38 0910578 0910578 SHIFTER-CLUTCH DOG 1 $113.22 $101.90 <br />39 0313448 0313448 PIN 1 $2.91 $2.62 <br />40 0324369 0324369 SPRING 1 $2.59 $2.33 <br />41 0307551 0307551 DRAIN FILL PLG 10P 1 $3.07 $2.76 <br />42 0311598 0311598 WASHER 10 PK. 1 $1.00 $0.90 <br />43 0324766 0324766 THRUST WASHER 1 $28.61 $25.75 <br />44 0328096 0328096 SCREW 1 $4.62 $4.16 <br />45 0910312 0910312 SHIFT ROD 1 $30.33 $27.30 <br />46 0393023 0436745 Use 0436745 1 $11.07 $9.96 <br />47 0318544 0318544 DRAIN SCREW 1 $6.95 $6.26 <br />48 0311598 0311598 WASHER 10 PK. 1 $1.00 $0.90 <br />49 0323362 0323362 SHIM-PINION-003 AR $1.94 $1.75 <br />49 0323361 0323361 SHIM-PINION-004 AR $2.77 $2.49 <br />49 0314745 0314745 SHIM 005 AR $2.70 $2.43 <br />49 0314742 0314742 N/A 84 AR Please Call Please Call <br /><br /><br />this is a drive from and 83 2.5 but you really need a manual<br /><br />tommays
