I have a 03 Reinell 200 LSE with the VP 5.0 GL motor. A couple weeks ago the alarm started going off in the boat. All gauges were reading fine, the oil pressure and temp gauge read normal. Nothing seemed out of place. I checked the oil level and it was fine. But still no luck of getting the alarm to go off. Something is triggering it and I believe it might be 1 of 3 things. I believe it maybe the water pump sensor, oil level sensor or the outdrive oil. I will be changing the out-drive oil on the boat first since it wont hurt to change it and it hasnt been changed out this year. Is there a recommendation of what brand to use to change the out-drive oil out with? I will then change the sensors out but I need help finding them. I cant seem to find a part number for the two sensors. Can someone assist with the numbers and where to possibility purchase them.
