I have a 1990 90 horse force that I finally got all the little gremlins worked out of it and running good finally other then out on the water I can not get over 4200 rpm and the engine is running very smooth. I noticed that when moving into gear it goes right into gear but you move the throttle to about 3/4 before it starts to engage the throttle linkage on the carbs. Is this maybe a adjustment issue? Me and my brother also after having it at full throttle he reached over and moved the linkage and it went to the 5000-5500 rpm with no problem as well. This is my first boat so any help would me much appreciated thank
