northvanwatertaxi
- May 25, 2006
- 110
Hello thanks to everyone that helped, I'm still having problems with my fwc 302 ford engine with pre alpha merc drive.
It runs fine at idle, but at cruising it still overheats.
The raw water pump is new and working great.
so is the thermostat. tested it in water
manifolds clear so are risers they are ok to touch
temp is 130 at idle and will run fine at 1000 rpms
haave back flushed engine with circulating pump off
there is no water in drive oil or engine
has tons of power and engine sounds good
any idea what else to check?
